Olympus zoom gear to use in Nauticam housing
Started by Vimal ·
  1. Hi,
    I recently moved from olympus housing to Nauticam housing for EM-5.
    I was trying to see if I can use the olympus made zoom gear for olympus housing
    in Nauticam housing with any minor modification. (both for 60mm and 9-18mm/14-42mm lens)
    The only thing which was stopping is the width of the gear teeth in olympus zoom is thicker
    than the nauticam one, and this inturns pushes the lens release buttom against the gear when used
    in nauticam housing.
    Has anyone done any DIY modification of olympus zoom gear to be used in nauticam housing??
    Any input will be welcome.
    Regards,
    Vimal
