I broke my PT-020
Started by apete ·
I broke my PT-020
  1. I broke my PT-020
    Hi,
    What kind of glue should I use on the clear plastic part of a PT-020. I assume it's the same kind for all "cheap" underwater housings - the ones that the camera manufacturers sell.
    The broken parts are two of the four "feet" that the metal plate holding the tripod socket/screw stands on. They were so weak they broke when I removed the plate. Not much force - I used a screwdriver the way anyone would think acceptable/correct.
    /Anders
  2. I tried using "Repair eXtreme" from Plastic Padding. This did nort work well!
    Now it feels like I have a problem. I need a new foundation for the tripod plate. The broken off parts can no longer be used.
    The housing material seems to be too "fat". Will epoxy work?
    /Anders
  3. FYI
    I just talked to a company that work with palstic. They told me that the glue I need is not sold to consumers (in Sweden). You need a license to deal with it in any way (sounds scary).
    They could fix the housing for me, but it will cost me half the price of a new housing.
    /Anders
