Pre Flashes?
Started by SMY ·
Pre Flashes?
  1. Once again I need your support. I read always in flash manuals 'if your camera supports/makes pre-flashes do this or that'.
    So my question: when does a SLR like Nikon D850 makes per flashes and when not?
    Thanks and best regards, Sascha
  2. Hello Sascha,
    Camera rates reflected Pre-flash to determine main flash duration, for TTL automatic lighting control.
    Pre-flashes are emitted by external uw strobe using TTL-Converter, or by pop-up camera flash. In communication protocol of camera and flash, camera sends special commands regarding Pre-flash beginning and necessary Pre-flash duration.
    In common case, Nikon sends 2 Pre-flashes of different duration, Canon sends 1 Pre-flash of fixed duration.
    Yes, user can go to Manual mode (without Pre-flashes) at camera side, switch off Pre-flash camera commands for pop-up flash on both Nikon and Canon systems, very easy, - set M mode in pop-up flash partition of camera menu. Nikon and Canon, both have the same partition in camera menu for pop-up flash control. You can use it, if you have optical synchronization by camera pop-up flash.
    But for external land strobes control (or other TTL devices on HotShoe), only Canon can switch off Pre-flash by camera menu directly, Nikon traditionally does it by external devices. That is why Canon TTL-Converters use direct way, - camera command "M" mode" in menu, but Nikon TTL-Converters use indirect path for switching system to M mode by camera menu (for example "Auto FP", or other command), but final result is the same as in Canon system.
    It makes sense to better switch off Pre-flashes from camera side, if you want to shoot in M mode by your underwater system.
    Shooting in TTL, you must have Pre-flashes anyway, this is camera standard mode. This is necessary for automatic lighting exposure control.
    Edited by Pavel Kolpakov
  3. Dear Pavel, as always your answers help me a lot, thank you!
    Sascha
