FS: Nikon D800E + Nauticam NA-D800 housing + Zen dome
Started by lionofjudah ·
  1. This Nauticam NA-800 housing is in immaculate condition. Your chance to own this brilliant piece of engineering. Ergonomic features of Nauticam include joystick to scroll diagonally, Nauticam buttons are placed at an angle for use with the least effort. I prefer the wider surface area on these Nauticam buttons because your soft wet fingers will appreciate it after being in the water for hours. The convenient thumb button for playback and ISO is a joy to use. Nauticam has very responsive trigger (well maintained, just changed the spring) and back focus thumb button. The housing is equiped with a moisture alarm. This setup has never experienced a leak or flood before. the rubber grips sheds a bit of 'skin' , merely a cosmetic thing
    D800E body. Better than the D800. The E is without the AA filter to produce sharper images. 36MP sensor. Still a very powerful and reliable camera. slight scuff marks underside of the camera from harness wear. Very well cared after camera always stored in dry cabinet. Please ask for most recent photos from this camera to see its incredible detail.
    64GB CF extreme 120mb/s Card + 2 original Nikon Batteries + third party D800 Battery Grip
    Optical Flash Trigger is undoubtedly necessary to push this setup to its limits. Faster , longer and more responsive burst fire for the strobes. Also, save battery power using flash trigger. $395 AUD
    L base plate customised for D800. this is a solid piece of CNC base plate for tripod. very good for shooting landscapes , easy switch to portrait. Acca swiss. This is already worth $150 AUD
    Bundle includes a Zen Glass Dome DP230. Note: has a scratch in the middle and hazing from the glass on the sides. Still produce incredible photos, please ask for photos, you can hardly see the scratch only if you shoot really straight directly against the sun. This dome is worth more than $2K AUD
    Total bundle: $5100 AUD
    everything except Zen Glass Dome: $4600 AUD
    buyer pays for postage and PayPal surcharge. Item based in Cairns, Queensland, Australia
    email : leonardlele A T yahoo D O T C O M
  2. includes spare O ring as well. The 2 sacrificial anodes on the base of the housing are still in top condition. This indicates the amount of use and time in the water of this housing.
