FS: Zen 100mm Glass Dome, Nauticam Macro Port 41, Tokina Zoom Gear
Started by allyoctopus ·
  1. FS: Zen Mini Dome, Nauticam Macro Port 41, Tokina Zoom Gear
    1. Zen 100mm Optical Glass Dome Port, DP-100 for Tokina 10-17mm Fisheye lens
    Used glass mini dome port, selling as I need a dome that I can accommodate rectangular lenses. This is a brilliant dome as many know, selling for £830 new. This mini dome does have a few issues. It as one small 2.5mm surface scratch (see arrows on photos) which on occasion will show up in photos as a little smudge, generally if you are shooting close up. On other occasions the close focusing of the Tokina means it will sporadically focus on the scratch and you have to move the focus; this doesn't happen often but needs to be mentioned. There are also water stains around the outer sides of the glass which when used in very bright light will show up in photos if hit at the right angle. They never appear when it is cloudy, but again worth noting. I never had any issue using the dome port in its condition and I would happily continue to use it. The price on this port is reflective of the condition. It is also an option to send the dome port to Zen in Florida (or elsewhere?) to have the glass replaced, but again I was fine using the port as it is. It comes with covers for both sides of the port. Price is £375.
    2. Nauticam Macro Port 41
    Used macro port, I had a 60mm macro lens behind this port. Some light water stains on the acrylic, these never show in photos and I do not believe they are there when the port is wet. There are also some scrape marks on the side of the port where the black paint was scraped off, you can see this in the second photo of the port. It comes with covers for both sides of the port. Price is £215.
    3. TC1017-Z + 1.4 for Tokina 10-17mm lens with Kenko 1.4x teleplus pro 300
    In very good condition, not used much. Price is £115
    Located in the UK, happy to post anywhere in Europe. All sales final, no returns.
    Edited by allyoctopus
