questions about Hartenberger Strobe 250
Started by deepdiversa ·
  1. Hello, I just purchased a Hartenberger Strobe 250. It is being shipped to me currently so not yet in my possession but I am unsure of the sync cord connection to the strobe. Any one have one that can tell me what sync cord i will need. I currently use Sea & Sea cords. Also I will need to connect it to my Ultra light arms. Does anyone know what adapter i need to get a ball attached to the strobe? Thanks.
  2. Topic moved: Admin
  3. Their website http://www.hartenberger.de/english/e_hartenberger.html states this:
    Synchronisation-Cable
    The supplied standard synchronisation cable with the NIKONOS-V plug can be removed from the strobe allowing the slave mode without a cable dangling from the housing. This also means that a defective cable (expendable component) can be user replaced without sending the strobe to an authorised repair workshop.
    A special feature first developed by us is the double seal NIKONOS Plug. The innovative positioning of the second O Ring provides 100% more safety and security in sealing. The plug’s thread is also kept dry whereas the original plug’s thread is surrounded by water. This prevents the vacuum which is generated when removing the plug, thus sucking water into the socket. Corrosion of the threads is also avoided.
    However, Hartenberger is a excellent company with a very strong customer service, write them a email and they will be glad to answer your questions.
    Chris
