Rotary encoder settings on new UWTechnics TTL converter?
Started by mackman ·
  1. Hi, just replaced my non-TTL converter with a TTL one. The new one has a rotary encoder with 10 or 16 (I forget) possible settings, but the included instructions refer to having two switches with 4 possible settings. Anybody know where I can get the correct rotary encoder settings for Inon Z330 strobes? Thanks, Ryan
  2. Just to clarify, this is the Nauticam 26308 designed by UWTechnics for the D5/500/850. Instead of the two little switches, it has a little rotary dial. I'm guessing if the switches are both supposed to be off for the Z-240s then the dial should be at 0 for the Z330s, but it would be good to see the official answer. Thanks again, Ryan
  3. Hello Ryan,
    Rotary switch positions are following:
    0 - Manual mode (TTL protocol is switched off)
    1 - Z240, Z330
    2 - YS-D1
    3 - YS-D2
    4 - YS-250
    5 - DS161, DS160
