Problem syncing ys-d2 flash
Started by Pilotrob ·
  • 13Posts
  • 13Replies
  1. I am having difficulty getting my flash to sync with my Olympus Om-d mark 2 camera. Any suggestions?
  2. Hi,
    using electronic cable or fibre wire?
    Which sttings?
    Regards,
    Wolfgang
  3. Not sure. The one that came with flash. It plugs into front hole above port. I am not sure which settings to use.
  4. I am having difficulty getting my flash to sync with my Olympus Om-d mark 2 camera. Any suggestions?
    Which OMD do you have, 10, 5, or 1? Does it have an electronic flash built-in or as a separate unit for the hot-shoe?
  5. 5. It has a hot shoe and I have small flash attached there.
    I guess it is a fire wire
  6. 5. It has a hot shoe and I have small flash attached there. I guess it is a fire wire
    Fire wire? You mean the cable to the strobe? If it plugs into the front of the housing, it is optical. Does your camera's small attached flash fire when you take a picture?
    What kind of strobe is it?
  7. No the flash is not firing. Yes it must be an optical cable
  8. No the flash is not firing. Yes it must be an optical cable
    U need the flash of your camera to fire then the fiber optic cable can carry that light to your strobe to 'fire' the strobe
  9. If the flash works on the camera, but is not firing the strobe at all then you have a problem with the fibre optic cable by the sounds of it.
    If the flash is working and the strobe is firing but not lighting the picture you have to alter the settings.
  10. Ok thank you Will try to see why camera flash is not firing
  11. It is possible that the small flash on the camera is not in the raised position inside the housing.
    Take the camera out of the housing and see if the flash fires. If not make sure it is raised up and try it again.
    A problem many of us have had (or maybe just me) in the water with the flash down.
    Bill
  12. From memory on the EM1, I suspect the 5 is the same, you can switch the flash off even though the flash is in the upright position.
    Check your flash settings on the camera.
  13. Hi,
    yes, check if flash is activated.
    And not to the anti red eye mode.
    Best is the fat white flash sybol.
    And the flash has to be poped up.
    Try that outside the housing. If it works, inside.
    Then you should be able to see the flash throught the sync cord plug.
    If the ys D2 is still not firing, have a look for either the original Nauticam or the original Sea & Sea sync cable.
    Second should be the newer version with the black plugs.
    The D2 is not really sensitiv, so it needs a lot of light to ignite.
    Regards,
    Wolfgang
    Edited by trimix125
