For SALE: NIKON D800 & NAUTICAM D800 HOUSING
Started by rhkdiver ·
  1. FOR SALE: NAUTICAM D800 HOUSING & NIKON D800
    1) NAUTICAM HOUSING FOR NIKON D800. HOUSING ONLY, NO PORTS.
    INCLUDES: COMPLETE INTEGRATED VACUUM SYSTEM, + 2 WIRED NIKONOS STROBE PORTS (IN ADDITION TO INCLUDED FIBER OPTIC PORTS)
    HOUSING USED ONLY ONCE IN THE OCEAN. PRIMARILY USED AS A POOL HOUSING
    2) HARDLY USED NIKON D800 ONLY 6400 SHUTTER ACTUATIONS. INCLUDES: BATTERY, CHARGER, STRAP. SOFTWARE
    SELLING AS A PACKAGE $2000 PLUS SHIPPING. WILL ONLY SHIP IN USA
    CONTACT: ROD KLEIN 310 404 4159 rhkdiver@gmail.com www.rhkuw.com
    SEE PHOTOS:
    THE NAUTICAM NA-D810 UNDERWATER HOUSING
    The NA-D800 is an evolutionary marvel. A long list of pioneering engineering breakthroughs from previous Nauticam designs are now standard in NA-D800. The patented housing Locking Latch System has received acclaim worldwide for its ease and functionality. These recessed latches are equipped with safety locks, reduce bulk and require minimal physical effort to engage and release. Port changes have never been simpler than utilizing the Patented Nauticam Locking Port Release. No wrestling, no twisting, no misalignment – just seat and lock. Lens changes are also easily accomplished without removing the camera from the housing using the lens release button logically accessed on the housing front. The lightweight, rugged Nauticam handles are generously contoured with a durable over-mold process of comfortable non-slip rubber. The vacuum monitoring and leak detection circuit provides peace of mind by enabling the user to ensure that their housing is water tight before entering the water.
    The NA-800 is a shining example of the best that Nauticam has to offer. Every control placement is well thought out. Every button, lever and switch considered not in terms of what is easier for the designer, but what is right for the shooter. An excellent example is the patent pending Multi Controller Pad that is located within easy reach of the right thumb. The device virtually recreates the Nikon multi selector on the back of the NA-800 housing allowing full multidirectional use of this powerful tool (including diagonal movement). No other manufacturer has this. Camera loading is "drop in" simple, with no controls requiring pre-alignment, allowing the fastest and easiest setup possible.
    Core camera controls such as shutter release, aperture, shutter speed, live view, info, exposure compensation, depth of field preview, Fn, flash exposure compensation, focus mode, AF/M and zoom are located at the user's fingertips. Dual thumb levers, located on the right and left sides of NA-D800 pull important camera functionality from the back of the housing out to the handles. This allows quick access to Video Record, AF-ON (for thumb activated focus), ISO and Image Playback. Complete control of the camera is available from the ergonomic rubberized handles.
    INTEGRATED VACUUM CHECK AND LEAK DETECTION SYSTEM
    The Nauticam vacuum check and leak detection system is shipped with NA-1DXII as standard equipment. Combined with an accessory vacuum valve (PN 25625), this monitoring system provides constant updates on the water tight and safe-to-dive status of the housing. A simple color coded LED lighting system lets the user know that the vacuum is solid, or that the housing is losing vacuum. Leak detection is built into the same circuit, so if there is water intrusion, an audible and visual indication will occur.
    The Nauticam system is temperature compensated, eliminating false alarms caused by a change in outside temperature, or from a camera heating up on an action packed dive.
  2. SOLD
