170mm Zen dome
Started by bear35 ·
170mm Zen dome
  1. Hi
    Has anyone used the 170mm Zen dome for the Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED ?
    I have just noticed that the zen port chart say that it is compatible with the 170mm but my question is is there enough of a difference in quality to justify spending a lot more cash on the 230mm dome? Not to mention problems taking it abroad. Or is it just a case of bigger is better for this sort of lens?
  2. Any advice regarding the lens too if possible... Is it a good choice?
  3. Hi bear35
    If you dig around on WP I'm sure you'll find a series of posts about WA Nikkor lens and the Nikkor 10-24 by Adam Hanlon. I seem to recall Adam did a review of various WA options maybe 12-18 months ago. Again, if I remember rightly, the Nikkor 10-24 came out well for u/w use.
    My experience has been that DX lens are "generally" fine with a 170mm dome. It's the FX lenses that tend to need a 230 dome if you want sharp corners with a rectilinear lens.
  4. Hi Tim
    Thanks for the reply...
    I think I was actually reading that post before but couldn't find it again. I will have another search for it.
