Lens stuck on Nikonos III
Started by redgrouper ·
  1. Hi all,
    Bad surprise after a season off diving, impossible to pull and twist my 15mm lens off my nikonos III as usual. No matter how hard I pull ...
    I tried to let a few weeks go as I thought it might be a vacuum effect created from temperature variation, I even tried to leave it in lukewarm water with no result.
    Any piece of advice?
    Many thanks
  2. To insure vacuum is not a problem, remove flash cable/plug .
    Remember to replace before submerginp again.
  3. To insure vacuum is not a problem, remove flash cable/plug .
    Thanks! I did not think about that.
    Only issue is, I have never used flash and it is going to be a challenge taking the screw cap off, seems to be completely stuck.
    Edited by redgrouper
  4. soak in SaltX
  5. Or wrap something around it soaked in a mix of white vinegar and water and leave overnight.
