Nauticam Macro port 45 Nauticam mini extension ring 30
Started by rrogerstwo ·
  1. Nauticam Macro Port 45 with focus/zoom knob (36128)
    Nauticam Mini extension ring 30 (36630)
    Selling both $300.
    Edited by rrogerstwo
  2. Is the port compatible with the Leica 45mm lens?
  3. Is the port compatible with the Leica 45mm lens?
    Don't know. You would have to ask Nauticam.
  4. Hi, if it´s the NA 36135 it will work.
    Kind regards,
    Andreas
    From the NA site:
    This Nauticam Macro Port 45 is designed for housings supporting the N85 Port System. The front of the port has integrated 67mm threads for accessories.
    This port is designed to support the following lenses:
    •Leica DG Macro Elmarit 45mm F2.8 ASPH
    •Nikon 1 Nikkor VR 10-30mm F3.5-5.6
    •Sony E Mount 30mm f/3.5 Macro
  5. The 36135 doesn't have the knob. Usually the zoom o manual focus knob is on the housing itself.
    BTW it should be the seller to give complete info on the item is selling. Not me guessing what is it.
    Bye
  6. Hi is this still available?
