Need advice on Fisheye / Wide angle lens for D850
Started by SCUBA Hank ·
  • 16Posts
  • 16Replies
  1. Hello!
    So I am shooting the Nikon D850 in a Nauticam housing and have been told the Tokina 10-16mm lens is un-fit for this camera due to the high resolution of the camera... Is there anyone out there that can explain this further to me?
    Should I really be looking at the Sigma 15 or the Nikon 8-15mm?
    Furthermore, does anyone have any experience with the Nauticam N120 8.5-inch Acrylic Dome on the D850? I am concerned about weight with a glass port and I want to do Split Shots so I have my eye on this port.
    Any info on using the Tokina on the D850 or opinions on the Sigma over the Nikno 8-15 are much appreciated. I like to get advice from other shooters (who aren't the ones trying to sell me the products) :).
    Cheers-
    Hank
  2. Although I didn't address it in the D850 article, the 8.5" acrylic will shoot about like the Zen DP170. I shot it on my D800 with the Sigma 15mm FE and it's fine. However, it is so light as it creates a large bubble at the front of the housing that ends up twisting the housing up. It'll be worse on the D850 which is much lighter. The 8.5" will not work well with any of the mid-range zooms either with poor corners.
    My choice is a 230mm Glass dome. The camera shoots very well with it and it balances well. The larger the dome, the better you can shoot over-unders. If you're just going to shoot the Nikon 8-15 or Sigma 15, then the Zen 170 or Nauticam 140 glass domes work well and are smaller for CF/WA shots.
    BTW, while the Tokina can shoot at around 12mm on FX cameras, but it doesn't have anywhere near the resolution that the FX lenses have, especially for the D850.
    Edited by JackConnick
  3. Thanks Jack! That's great info and your last sentence answered the real question about the Tokina... As I was fearing, it looks like it's time to upgrade my lens'...
    BTW, while I have your attention, what other lens do you recommend for shooting Wide Angle Video (Sharks, Mantas etc)?
    -Hank
  4. Hank, those are all in the article with examples. Most people shoot the 16-35, I like the 17-35, but I had very good results with my 60mm behind a small dome in clear water.
  5. Thanks all. I am about to pull the trigger on the Zen 170 Dome with the Nikon 8-15 and the Nikon 16-35... and of course the proper extension...
    I just need to research the Nikon 20mm prime a little bit more before I turn over my CC # :)
    -H
    Edited by SCUBA Hank
  6. Hi Hank
    Just to pick up Jack's point on shooting with the 16-35, do be aware that using 170-sized dome with this lens is likely to result in soft corners. I used the 16-35 on a D800 in a Subal housing with an 8" dome and the corners were horrible even with the correct extension ring and a diopter. It's ok if the edges of the image are nondescript background - eg just the blue. But if there is a reef or, say, divers then the softness is very apparent. I had to upgrade to the much larger 230 dome to get over the problem. The Sigma 15mm is fine with an 8" dome however. The Nikkor 8-15 I don't know.
    Just be aware if you are going to go with that Zen 170 and use the 16-35.... the results may not be great.
  7. Tim! I appreciate your reply and honesty... I have been spending so much time trying to justify the costs of everything that I was making the wrong decisions.
    Today I ordered the ZEN 230 Glass Port for the 16-35 and bit the bullet... Not point in doing it wrong right? Your reply came after I ordered it (and after a bottle of wine) so that helps me feel better about the decision...
    Next I need to figure out what Dome to get for the 8-15 but that is less of a rush for me.
    Cheers!
    H
  8. Tim! I appreciate your reply and honesty... I have been spending so much time trying to justify the costs of everything that I was making the wrong decisions.
    Cheers!
    H
    You can use a large dome with the 8-15 fisheye. In fact the results will be better than with a smaller dome. Even with just 12 Mp and the smaller DX format I got better results (as in sharp all the way to the edges of the frame) with a superdome compared to all the smaller ones.
    Tom
    Watch this video:
    http://wetpixel.com/articles/domes-without-the-drone
  9. Tim! I appreciate your reply and honesty... I have been spending so much time trying to justify the costs of everything that I was making the wrong decisions.
    Cheers!
    H
    LOL, I trust it was a nice bottle of wine, Hank.
    Yeah, good call I'd suggest on biting that bullet. When I moved to the D800 some time back, I was so disappointed after my first trip (to the Red Sea) with the WA images - which is the majority in the Red Sea., The edges with an 8" dome and the 16-35 were just crummy. The 230 dome is significantly better although it is a bitch to travel with.
    According to Subal and their port recommendations, the Nikkor 8-15 will work with either a 230 dome or an 8". I'm intrigued as to whether it will work with a 100/4" dome.....
  10. I just bought the zen 230mm for the 16-35, and I am in the same crossroads as you are, dont know if It is a better choice sigma 15 or nikon 8-15. I know the sigma doesnt need anything extra, but the 8-15 needs a zoom gear on my nauticam. If I get the 8-15 will the shades of the 230mm dome show up in 8mm?? Do I need to get the 100mm dome for it?
  11. I just bought the zen 230mm for the 16-35, and I am in the same crossroads as you are, dont know if It is a better choice sigma 15 or nikon 8-15. I know the sigma doesnt need anything extra, but the 8-15 needs a zoom gear on my nauticam. If I get the 8-15 will the shades of the 230mm dome show up in 8mm?? Do I need to get the 100mm dome for it?
    Yes, the shade will be seen in 8mm pix. At 8mm the angle of view is almost 180 degrees all the way around the image and not just at the diagonals as at 15mm. Find out if the shade can be removed - many can.
  12. Once you settle on lenses the next step is to consult the Nauticam port chart for Nikon lenses. For each lens they recommend the best port and will show other configurations that work.
    JW
  13. So it's official, I got the Zen 230 port, the Nikon 16-35 lens and the 8-15... Now I need to get a 2nd job!
    Off to Fiji in a few weeks.. Stay tuned for the results :) thanks for all the info!
  14. Welcome to the club! I just ordered nearly the same setup....I'm excited to hear about your first results....And hopefully my wife never asks about the total costs...
    Sascha
    Edited by SMY
  15. Welcome to the club! I just ordered nearly the same setup....I'm excited to hear about your first results....And hopefully my wife never asks about the total costs...
    Sascha
    Another member of the "it was an unbelievable bargain, honey" club :crazy:
    We should print a t-shirt
