OLYMPUS FLASH TRIGGER AND COMPATIBLE WITH NA-EM5II/EM1/EM1II
Started by Travel_Diver ·
  1. New OLYMPUS Flash Trigger AND COMPATIBLE WITH NA-EM5II/EM1/EM1II
    200€
    Nauticam flash trigger units allow the use of robust and reliable fiber optic cables to fire external strobes, providing dependable, rapid-fire flash triggering over fiber. Flash triggers allow motor drive shooting sequences, perfect for fast moving action.
    This flash trigger plugs into the compatible camera hotshoe and provides an optical signal for fast, continuous strobe firing. Automatic TTL flash control is not supported by this flash trigger, flash power is set manually on the strobe itself.
    TECHNICAL SPECIFICATIONS
    Construction: Body: PC+ABS Dimensions: NA-EM1: Approx. 37 x 36 x 40mm
    NA-EM5II/EM1II: Approx. 37 x 49 x 42mm
    Weight: NA-EM1: Approx. 42g (w/ batteries installed)
    NA-EM5II/EM1II: Approx. 45g (w/ batteries installed)
    Battery: CR2450 x2pcs Operation: This a manual flash trigger only and has no TTL function. Flash Capacity: Approx. 10000times Compatible housings: NA-EM1 / NA-EM5II / NA-EM1II Compatible strobes: INON: Z240 type 4, D2000 type 4, S2000
    Sea&Sea: YS-250, YS-D1, YS-01
  2. 190€
  3. 180€ BUMP
  4. make an offer :bye:
  5. It's sold!!!
