SEALUX CD70 and CX800 for D70 and SB800
Started by stone ·
  1. SEALUX CD70 and CX800 for D70 and SB800
    Hi!
    I visited the website of Sealux, I saw the following message:
    If you wish a precise TTL flash control with the digital Nikon cameras this is above all possible with the SB-800DX flashgun! For this we have designed the CX800 housing which meets all requirements.
    Does it mean that it really support TTL?
    Stone
  2. Hi Stone,
    of course. It's a Nikon system gun.
    regards,
    Julian
  3. Hi!
    So do you think I should go for Sealux?
    As both Ikelite and Sea and Sea are not support TTL at the moment.
    Correct me if I were wrong.
    Stone
  4. Hi,
    I would not select a certain housing because the same manufacture offers a land strobe housing as well.
    There are other points which may make your decision (price, build quality, ergonomics, and so on).
    There are different strobe housings available, for example Subal, UK-Germany, Seacam......
    You can combine one of these with your favorite housing as long as you make sure the housing builder installs the required bulkhead and wire-connections.
    Should not be a problem.
    Another question is if you want TTL with a system gun or if you prefer a manual amphibic strobe. There are lots of statements on this topic (TTL or not) in this forum.
    regards,
    Julian
