How to use Pinnacle Studio Ultimate with Backscatter red filters
Started by Sbiriguda ·
  1. I have Go Pro 6 and Backscatter 3.1 flip red filters, mostly I use Shallow and Dive. Until now I didn't add lights but I have one and will try to add it next time.
    I installed the trial version of Pinnacle Studio Ultimate version 21, and I would like to focus on this software
    I have to learn how to do editing. More or less, the idea is I should use the "enhance" function. Then use the selective saturation cyan, and also brightness, contrast, clarity, white balance etc. until I get a good result
    Any suggestions, links or previous discussions?
  2. You can also go into the "Corrections" tab, and under the "Color" button, there is a "White balance" choice all the way to the right. You get an "eye dropper" tool to use to help set your white balance. Depending on what you choose to pick with the eye dropper tool, it can often get you pretty close on the white balance, and then you can do the final adjustments using the process that you have outlined above. I also use Pinnacle Studio, and have for quite a few years now, and this is the workflow that I use on my video footage.
    Good luck, and have fun.
