My methodology to select the correct housing
Started by iainwilliams ·
  1. My methodology to select the correct housing
    I thought I would document the methodology and logic I used to determine which housing to purchase for my Canon G5 digital camera. Perhaps it may help others in their decision. I was indecisive as to whether to purchase the Subal or Ikelite housing.
    First of all I utilised a number of forums to solicit comments from other users and would be users of similar products. Wetpixel.com Digitaldiver.net and SCUBAboard.com
    The factors I weighed up were:
     Size and weight of housing
     Depth rating of housing
     Whether the housing was neutrally, positive or negatively buoyant underwater
     Attachment fittings for attachment of strobe and base plate (not all housings will operate with all strobes)
     Robustness & ease of scratching
     Ergonomics (large square housings are difficult to move about underwater)
     Lens ports (glass verses plastic) – the later can cause chromatic aberrations when shooting towards the sun (starbursts)
     Ability to add macro/wide angle lens to lens port
     The volume of air inside the housing (condensation problems?)
     Housing construction (aluminium, polycarbonate, plastic) and closure clips on the housing
     O-ring placement and sealing ability and reliability – is it protected or unprotected – easy to remove and service
     Housing visibility – what I mean here is whether you can see the camera in the housing or not. I judged this as important as a dark housing will allow the LCD to be more brightly illuminated, in contrast to a clear housing which will allow light to enter the housing causing possible difficulties in viewing the LCD. Also light entering the housing can cause extra reflected light to enter the lens. Furthermore, a clear housing will allow the air inside the housing to heat up more quickly which may cause condensation issues
     Water entry alarm or sensor
     Construction and ease of operation of knobs and switches – when wearing gloves
     Functionality of the camera in the housing
     LCD viewing through the housing. Is it framed, hooded, shaded or indented causing the LCD to be more easily viewed in strong sunlight
     Ease of repair in your country – not just the USA
     Whether the camera fits snugly in the housing and is easy to install
     Strobe connection. Either a Nikonos plug system and sync cord or an optically fitted cord (slave technology). The former does not utilise camera battery power, the later does lowering the life of your camera battery. Furthermore, if your camera is pre flash, there is the risk of heating the air inside the housing as the pre flash fires to trigger your strobe. Heating the air may cause condensation problems – and if it gets very warm your camera may go into auto shutdown mode (depends on camera type and model)
     Your requirements and the type of diving you will be doing (shallow, deep, snorkelling, etc)
     Life span of the camera before replacement
     Opportunity for ordering problems such as wrong attachments, plugs etc. Probably not an issue if you live in the USA, but for buyers in countries outside the USA, the wrong product sent can often cause innumerable and costly problems which consume considerable time, patience and frustration to sort out
     User, dealer and forum comments and the consistency of information received
    You may note that aesthetics (what is looks like) and price did not come into the equation.
    I went through this process, then looked at the price, and weighted up the pros and cons.
    Please note that I am in no way recommending or condemning either Ikelite or Subal. Both companies produce excellent housings, but cater towards different segments of the market. Additionally, some of the comments above may not seem important to you, and that’s fine. The list was compiled to help me in my decision. Ultimately, it is up to you, but I hope that some of these comments may assist to steer you in the right direction. Good luck……………..Iain
  2. I think the ikelite is every bit as good as the subal, in most every way, and half or less the price.
    If Ikelite makes a housing for your camera, you'd be silly to get anything else. They are really good. The clear material is a huge boon, because you can see any kinks or extrusions in the orings AFTER assembly! Until you've spent some time putting them together and taking them apart, (which seems to need doing a lot..), you don't understand how comforting this fact is.
    The subal is physically tougher, so if you get tossed hard against the rocks, underwater, it might take less damage, but if you don't knock your gear around, the ikelite is certainly tough enough, and clear!
    I've never had a flood, and been using ikelite housings for the n90s, (35mm film), for most of the 90s, and now for a G2 for a couple of years. I love them, and the company.
    My sig has some shots.
    Don
