Sea & Sea YS-D1 strobes (3)
Started by Aotus ·
  1. I bought these three strobes used in the spring for a project in an underwater cave. It was my first time using strobes, and it turns out these are (a lot) more power than I need. All three are tested on several dives down to a max depth of about 60ft and worked great. All three exhibited some corrosion on the battery contacts when I received them, but I scrubbed them with alcohol and haven’t had a problem. Two of them have the oem 100 diffusers, and all three are configured with the oem ball mounts.
    If I have no takers these will be up on eBay (seller: antillothrix).
    $350 each, shipped conus, PayPal only.
    UPDATE: the two with the diffusers are SOLD. One remains, with no diffuser, $350 shipped CONUS.
    Edited by Aotus
  2. I bought these three strobes used in the spring for a project in an underwater cave. It was my first time using strobes, and it turns out these are (a lot) more power than I need. All three are tested on several dives down to a max depth of about 60ft and worked great. All three exhibited some corrosion on the battery contacts when I received them, but I scrubbed them with alcohol and haven’t had a problem. Two of them have the oem 100 diffusers, and all three are configured with the oem ball mounts.
    I am very Interested in purchasing these. Can you reply to jessebruyn@gmail.com?
  3. two sold. The one on the far left (no diffuser) is still available.
    Also, thanks for the offers, but no trades please.
    Edited by Aotus
  4. Is the third strobe still available? thank you.
  5. All three are sold now!
