Nauticam SMC-1
Started by Beth Watson ·
Nauticam SMC-1
  1. For Sale: Used Nauticam SMC-1 $240.00 Free shipping within the continental US.
    Shows signs of usage. Glass elements are in great condition.
    Nauticam Super Macro Converter SMC-1 #81201
    Nauticam's great new Super Macro Converter gives an approximate +15 of magnifying power without any distortion or aberration. Additional macro lenses can also be stacked with it for amazing clarity and enlargement.
    There are three key advantages to this internationally patent pending new optical design:
    • Higher Magnification Than Other Popular Super Macro Tools with Increased Working Distance
    • Better Edge to Edge Image Quality, Higher Contrast, and Lower Color Fringing
    • Compatibility with “short” macro lenses that traditionally have not worked well with super macro accessories.
    Breakthrough Lens Design
    The SMC takes a radically different approach: treat the system - camera, lens, port, air, and water – as a whole, and account for the air-water interfaces in a conversion lens design to achieve the best image quality possible.
    Uncompromised Optical Quality
    The Super Macro Converter is constructed from lenses are precision crafted of specially formulated low dispersion optical grade glass, ground to the most demanding standards. These optics are assembled in a rugged hard anodized aluminum housing, that's nitrogen purged.
    Stunning Magnification
    When combined with a full frame camera and a 100mm or 105mm macro lens, provides a maximum of 2.3X magnification factor.
  2. Hi Beth
    What happened to the blue ring?
  3. Hi Triggerfish,
    Honestly, I don't remember, think I may have taken it off for some. But it really does not serve any purpose, other than for gripping.
  4. Hi...do you still have this smc-1?
  5. Hi Beth,
    Is the SMC still available?
    Regards,
    Eduardo.
  6. Hi Beth, is this still available?
    Thanks, Robotten
    Note: I will be with you and Phil in the Philippines
  7. Interested, is this still available?
