Nauticam NA-G7X Housing - $650
Started by UndrH2Oman ·
  1. Housing has 150 dives, never flooded, good condition, working very well! Comes w/ extra N50 port o-ring. Will consider offers.
    All of the basic functions and ergonomic enhancements that Nauticam users have grown to know and love are incorporated in NA-G7X. The housing is machined from a solid block of aluminum, then hard anodized to seal out corrosive salt water. It is closed via a simple, yet secure locking rotary latch. The right side of the housing is sculpted to fit the palm of the user's hand, and Nauticam's two-stage shutter release lever provides clear differentiation between the half press and full press shutter release positions. All functions are clearly labeled, and an m14 accessory socket allows an optional vacuum valve to be installed.
    The Nauticam leak alarm and vacuum monitoring system is installed as standard equipment. This system provides an audible and visual alert to any water entry in the housing, and when combined with an accessory M14 Vacuum Valve (#25611) the water tight integrity of the system can be tested before ever entering the water and monitored during every dive.
    -Secure, easy to use locking latch
    -Ergonomic controls with size, shape and color differentiation
    -All camera controls accessible
    -All controls clearly labeled
    -Popup flash lever
    -Dual fiber optic bulkhead
    -Integrated leak detector and optional vacuum check
    -M10 mounting ball
    -Cold shoe mount
    -Interchangeable port mount
    -Standard port: full zoom through & m67 accessory mounting
    -1/4-20 tripod or tray mounting holes
    -Sculpted, sensitive shutter release
    -M14 bulkhead port for vacuum valve
    post-50859-0-40909000-1537738563_thumb.jpgpost-50859-0-28838700-1537738574_thumb.jpgpost-50859-0-79157100-1537738594_thumb.jpgpost-50859-0-45603900-1537738636_thumb.jpgpost-50859-0-79662200-1537738656_thumb.jpg
  2. Will take $550.00 + shipping in US
  3. Contact info: jwadea63@gmail.com
  4. $400 firm + $20 shipping
  5. OK.....leaving for a trip next week! $355.00
  6. SOLD......
