FS: Aquatica + Nikon D610 + more
Started by emilyfraser ·
  1. FS: Nikon D610 Aquatica system
    Nikon D610
    Shutter count at 49,373. It was my above water camera so decent use but have had absolutely zero issues with it. Sensor was recently cleaned.
    Includes:
    Body cap
    2 batteries (real Nikons) -still have great battery life in them.
    Charger (real Nikon)
    May still have box if you want it...
    Nikon 20mm lens
    Includes lens cap and back cap.
    No scratches or damage, has only been used inside housing so no outdoor wear+tear.
    Aquatica D600/D610 Housing with handles
    -No body cap included as they never sold me one.
    -All buttons functioning, on/off switch slightly finicky but could be fixed with the right tools (I will try again to fix in my spare time. Don't worry it works, just skips a little sometimes and you have to wiggle it.)
    -Dual Nikonos sync bulkheads (fully functioning)
    8" acrylic dome with dome shade and neoprene cover.
    -Acrylic element just replaced in the last year by Aquatica and has had minimal use since then so this is quite literally a brand new dome, which would cost about $550 new.
    Flat port (mini macro port)
    -This does have a small ring scratch on it however it did not affect my photos and the element could probably be replaced by Aquatica- I will call them and check.
    -This item doesn't make up much of the cost in the grand equation as I know the scratch isn't ideal.
    - Used twice.
    No end cap for either port as they do not come with the housing, even when brand new.
    Extension ring (0.65") #48456
    - I was using this to fit an older tamron 90mm into the mini macro port as Aquatica didn't have this on their chart- I had to jerry rig.
    - Can be used for tokina 10-17.
    Single Sea&Sea Nikonos to Nikonos sync cables- 2 of these
    Have a bit of salt on them but still function well. No leaks.
    Tons of spare o-rings included for housing/ports.
    Housing was overhauled once by Backscatter. Has never leaked and has been well maintained. No leak alarm/vacuum system installed. I am the original owner.
    $3000 US for the lot. I would be willing sell without camera if you already own a 600 or 610, the rest I would rather not separate, but message me.
    You pay shipping from Southwest FL.
    PM or email me emilyfraser714@gmail.com.
  2. Price for housing system without D610 (if you already own one) $2400 USD
  3. Price drop! $2,500 for entire system.
    Buyer pays shipping from Southwest Florida.
  4. Still available!
