Dive And See DNC-5A HDMI 5.5 inch monitor
Started by combatalex ·
  1. Hello all,
    This monitor is like new. Never been used in the water. It was used in an Electronics show as a functional demonstration unit.
    By default, the monitor was used with Seacam Sony A7RIII housing. I can provide you the bulkhead connector if your housing is other than Seacam.
    The monitor has HDMI Input and an additional 3G-SDI Output bulkhead connector (cross converter HDMI to SDI), which allows it to send an SDI signal to the surface.
    This set consists of:
    Sealed monitor
    Battery charger
    Bulkhead connector
    Cold shoe ball mount 1 inch
    Quick battery charger
    Monitor hood
    Price: $2160
    Original price is $2700
    For detailed technical information of this DNC-5A(HS) monitor, see (http://www.diveandsee.com/products/underwater-monitors/dnc-5a)
    Edited by combatalex
  2. Sold.
