Lightweight Carry On Options for large mirror less housing?
Started by Interceptor121 ·
  • 17Posts
  • 17Replies
  1. I have a LowerPro backpack that was fitting just fine my small mirror less housing.
    I now have a Panasonic GH5 with a Nauticam housing and this is taller plus it comes with integrated handles that make it too tall for the lowerpro bag
    I have therefore got one of this backpacks that measures 55x40x20 and expands to 25 if needed
    https://cabinmax.com/home/285-uppsala-expandable-cabin-backpack-5060505761696.html
    that are practically empty inside with the idea of fitting the bag that comes with the housing plus get another set of inserts for ports lenses etc. Obviously the whole set up would struggle with a large dome but I only have a small dome and a 6" wide angle port
    The nauticam case takes almost half of the back pack but I still have space to I thought of getting one of those to fill in the rest
    https://www.vanguardworld.co.uk/photo_video_gb/divider-bag-37.html
    The positive is that the bag with the insert weights much less than the LowePro
    I wonder if anyone has different solutions that minimise weight but provide maximum space?
    I will post some pictures of the set up once one of my last bits arrives
  2. I’ve just gone through exactly the same issue for my trip in 3 weeks.
    My ThinkTank Security Roller is just too big, too heavy and not useful with the tight rules of the airlines these days. Looked at camera backpacks but they are deep enough for my Atomos housing.
    I too looked at the MaxCabin bags, but read reviews to say the stitching wasn’t great - so with 10-15kg of stuff, I decided (for me) that it wasn’t the way to go if the straps start going, but volume and weight of these things look great!
    So... off my wife I got her old IT Luggage 2 wheel softsided roller, which weighs nothing, looks cheap (it probably was) and it’s got a rather feaching owl print LOL. But it’s 50x40x20 so going cheap, and using bubble wrap for the housings - everything fits.
    Days of Pelicase and ThinkTank are over on most airlines it seems [emoji20]
  3. You could use an insulated cooler bag. Also doubles as a personal rinse tank while you are diving. I just did that for my trip to Mexico this summer. Waterproof, padded, but it's only one large compartment, so you might want to wrap individual ports and stuff with clothes to protect them in the bag.
  4. The coolers I can find are too small around 30 liters
    This is the solution I have built
    It consists of a cabin max upsala bag 55x40x20 expanding to 25 cm
    The Nauticam bag that came with the GH5 housing
    A vanguard divider bag 37
    It weights a little bit less than a lightweight trolley at 2.6kg but it is already padded and ready to go
    Edited by Interceptor121
  5. I try to do a crafty combination of a backpack (try to make it look as light and small as possible), a TSA sized suitcase carry-on roller suitcase and have even purchased a jacket w/ a TON of pockets for lenses and anything else that won't fit in the backpack and suitcase.
    If I explicitly state that the carry-on pieces BOTH contain photography equipment that I am unable to check, they will usually take a look, and after a bit of consulting, let me through. But this has mainly been w/ EVA Airlines going to Indonesia. I haven't tried other airlines yet.
    I just purchased a hard case that I'd like to try to use as a carry-on and if they make me check it at the gate, I won't feel so worried about what will happen to my stuff.
  6. I have a Think Tank street walker hard drive back packand it fits in my EM-1 MkII housing and the Zen dome port. In that bag last trip II had the 170mm Zen dome, the 100mm Zen dome, 65 macro port, the Oly 12-40 and 60mm macro, Pany 7-14 and 8mm fisheye, two INON Z-240s as well as spare batteries and odds and ends. in the bottom sot I had my ultrabook laptop. I had the camera in housing
    This is carry on legal size and if it won't fit in the overhead lockers will fit under the seat in front .I got it in the overhead locker on a Garuda regional a CRJ-1000 on a recent trip, No problem at all on the 737s. One thing to try is avoid budget airlines that charge for baggage, if they make you check it they can charge you.
    Think tank stuff is very strong and well made.
  7. Hey Chris - Id love to see a photo of that backpack fully loaded. I have close to the same system and have yet to find the right solution for everything. Robert.
  8. Here you go,
    It's not 100% loaded as I had to repack it to take the image, missing are some batteries, fibre optic cables, Oly mini flash etc.
    Bottom row L -> R: NAEM1-II housing , strobe/camera batteries
    Middle row L -> R: Macro port 65, 2x Z-240 Zen DP-170 type II port
    Top row L -> R: Zen DP100 port, Pany 8mm fisheye, 60mm macro, Oly 12-40, Pany 7-14.
    Camera is in housing, laptop in slip in section under it all, I also take a hand carried bag that holds toiletries, Misc accessories including o-rings, vacuum pump, etc. etc.
    This will fit under the seat in front of just about any aircraft and overhead on most, as I said this went into overhead of a Garuda CRJ-1000 commuter jet.
    This is the pack: https://www.thinktankphoto.com/products/streetwalker-harddrive-v2
    I've had mine for about 8-9 years and it's still going strong. In 2014 I went to Ecuador and had a Canon 500mm f4 and 1D-IV and a bunch of other lenses in it. It's quite versatile.
    Edited by ChrisRoss
  9. So after a lot of deliberation I packed my items. The issue that I find is that over 10 kg is really not bearable for a backpack
    Only the keldan lights and spare batteries I have are 4.5Kg so I ended up with a standard trolley 56x45x25 (I am flying Biritish airways)
    I kept a vanguard divider bag 37 for the ports and glass items everything else went in divider bags (cabinmax) with bubble wrap
    So
    GH5 housing
    Keldan 8x with spare batteries and power supplies and floats
    2 12" 2 8" 4 5" arm segments 10 clamps
    sola focus light
    two ports
    all batteries and chargers
    two strobes
    Total weight 16.6 Kg....
  10. I've been using AO Coolers for 10 years for my rigs. International (Asia) is tough for weight restrictions, 7KG. Fits my GH5 and Nauticam housing, Small HD monitor and Nauticam housing, all my lithium batteries and GH5 lenses. All that just under 15lbs. The cooler also serves as my carry bag to dive shop/on boat and rinse tank. Honestly, I've yet to come across a better solution.
    In your scenario I understand not wanting to "Pack" it around. Normally when I fly unrestricted Carry on weight add to the above load out my strobes x2, sola lights x3. I basically just set the cooler on top of my wife's roller and cruise through the airport.
    Edited by sideways
  11. I've been through many bags and my current favorite (just been to Indonesia and back) is the Lowepro Whistler (larger one).
    Its shape is unique.
    Camera compartment is deep enough to hold my Aquatica D810 housing. My 9.5" dome goes in the outer expandable clothing pocket. Its fairly narrow so fits in tight overhead spaces, using the vertical space instead of horizontal.
    I've fit it when people with much smaller rollers have to go back and gate check. Bonus is that the camera compartment can be removed if going on a flight with small overheads (done that too). Of course you have to deal with carrying all the weight, but I find airlines don't usually bother questioning & weighing backpacks like they do rollers.
    I also have a Thinktank Airport Security which is a great bag, but just too much for tight carry-on rules these days. That served as my 2nd checked bag on my latest trip, carrying strobes, arms, torches, tools, chargers etc. Also a Peak Design Messenger as 'personal item' which handles one body and a couple lenses. Overall worked well managing a ton of UW and topside camera kit.
  12. ...and my 5 cents:
    Manfrotto BumbleBee 220 (https://www.youtube.com/watch?v=AO2SnpkG-58)
    Been using it for years now, and it works very well. Good quality, and thanks to being a backpack, and of a smaller appearance it usually does not attract any attention at the check in :) Easily fits into the overhead lockers or under the seat.
    As for all the crap inside:
    -Nauticam GH4 housing + 6" dome + 4.33" fisheye dome + 45 macro port + housing handles
    -2 Sola lights + charger
    -2 dive computers
    -2 Inon Z-240s
    -Mares torch
    -Z-Bolt laser
    -CMC-1
    -2 lenses 45 and 12-35
    -misc crap - pump, Nauticam tool, o-rings, 5 sets of Eneloops, some paperwork, camera charger, usb cables, strobe ball mounts, extra ball mounts for housing, fiber optic cables, 3 pairs of diffusers, yellow filters etc
    -13" laptop
    Basically most of the stuff..only things that travel separately are: GH4 body + 7-14, 8,14-140 + 2 fluro filters (small camera bag, over the shoulder), clamps, floats, arms, dyi snoot, AA battery charger (main suitcase)
    Total weight round 12 kg, and that is including a laptop. Again, since it looks smallish, nobody bothers to check it. Once got pulled by some overzealous SwissPort employee, but as soon as the nearby Garuda rep arrived and heard it is a UW camera, it was immediately waved through, no further questions asked. Never flew via US though so dunno about the famous TSA...
    Pics attached (took out two plastic bags with some paperwork, o-rings and tool, that usually are on top of the pile)
    Edited by makar0n
  13. My two cents. I use a D850 in a Nauticam housing with 105mm macro port and 230mm dome port. I have to split it into three bags. Whole process is shown here:
    http://www.cjcphoto.net/uwcamera
  14. I shoot a Nikon D850 and use about 2/3 of a Think Tank Airport International 2. 0 roller bag for camera body, lenses (8-15mm and 105mm), viewfinders (45 and 180 deg), batteries - both for camera and strobes. Also in the roller bag is the focus light, hard drive, back up button batteries, etc. With the room left over I put in my medicines, a change of clothes, and a few odds and ends. Weight comes in at 33 pounds. I also carry a backpack or shoulder bag with laptop, iPad, etc. etc.
    For the hardware, housing, floats, and all that I have a Think Tank Manager 30. There is some room leftover in for some clothes. Scuba gear has it's own bag.
    I figure the price of attendance is paid at the counter in baggage overweight fees.
  15. I keep my dome port, camera, lenses, regulator and dive computers with me on the carry on. Everything else goes on the checked luggage nicely padded by lots of underwear :) This works extremely well specially on the return flight with dirty laundry.
  16. I use a Think Tank Airport International roller for my dive camera gear and a Think Tank Accelerator for my above water camera gear.   The roller bag has SIGNIFICANTLY less room inside due to the handle and wheel wells.  I still use it because I'm tired of carrying that much weight on my back.   The backpack gets used more for car trips now, but also international non-dive travel.  Both bags will fit under a normal airplane seat or in regular overhead compartments.   Under the seat it sticks out about 2 inches, so really restricts your feet.   But doable on a small commuter hop, like between two Hawaiian islands on a puddle jumper.
    I have a Nauticam housing for a D850 that takes up 1/3rd the space.   A 230mm dome port takes up most of the rest.  I layer bubble wrap around things and add in two YS-D1 strobes, a 180 degree viewfinder, a couple of strobe arm pieces and all the spare batteries, plus a few little bits.   My macro port and 90mm dome port extension have to end up in checked luggage, packed in between BCD, fins, a lot of neoprene and a 36 quart AO cooler stuffed on top.   My camera goes in the housing.  My lenses (105mm and 16-35) go in a Think Tank Speed Racer waist bag, along with a Sony RX100 inside a Nauticam housing as emergency spare camera.   I also put my dive computer in there, but the rest of the space is mostly filled with travel stuff, like passport, wallet, water bottle, book, medicine, etc.    It's a system that has been working for me for 5 years now.   I hate putting any glass in checked luggage (the macro port), but it's been fine, as has been my laptop as well.  (I stick the laptop inside the AO cooler sometimes for maximum protection, but it is always opened and checked by TSA.  Last time they just took the laptop from inside all its padding and repacked it right on top.
    In order to make this work, I have to remove the mounting posts that stick up highest on the Nauticam housing.  I use these for a rope handle.  I bring a small pliers and ziplock bag to hold the parts, including 3 plastic washers on each side.
    Craig Johnson
  17. I use the Think Tank Airport commuter. It's advertised as fitting carry on restrictions, but fully packed I doubt that is true. However, because it is not a roller but a backpack I get through places that other bags this size don't get.
    I was in Egypt last week. On the way there, I noticed that the check in staff was handing out little tags for carry on size. When we got to the check in she asked if we had any hand luggage. I motioned at the back pack (I always carry it on the back for check in). She then said the tags were only needed for the larger roller-bags. The bag of the guy just in front of me was certainly smaller than mine.
    On the way back it was even worse. A guy in front of me on the queue had to show that his bag fit in one of those boxes they have to check the size. It barely didn't fit. They argued for a while and in the end he was allowed to take it on. I got really worried, but when I got to the check in, I was just handed a little tag for my back pack, that surely would not fit into the box...
    Carrying the back-pack around can be annoying though, but I believe it's worth it.
