should o-rings be removed from the housing if the housing is going to be stored for any length of time?
tia
tia
Yes, you should remove the O-ring from the housing if you will store it for an extended length of time; this prevents the O-ring from taking a "set" if you keep the housing closed.
HTH,
Matt
Also, a little lube to keep them supple
