Fix Neo MINI 1000 Underwater Focus & Dive Light - $225 US
Started by UndrH2Oman ·
  1. I went to a smaller set-up and no longer need. I had 3 dives with it. Great for macro and video! Selling as used, but is in immaculate condition!
    The new FIX Neo Mini 1000 SW, The perfect compact video lighting companion. This new iteration of the Neo Mini features a video pleasing 1000 lumens of white light in a 95° beam angle providing great coverage for today’s wide-angle lenses. A single press of the Neo Mini’s control button and the beam angle switches to a 25° spot beam to isolate the lighting pattern for dynamic macro results. The Neo Mini is powered by a rechargeable Li-ion battery system that can be swapped with a fully charged battery between dives. Dive ready at a minuscule 160g, the Neo Mini rounds out with an automatic shut-off feature when a strobe flash is detected, SOS mode and distress mode. All-together, the FIX Neo Mini 1000 SW is the perfect lighting solution to any video genesis.
    The FIX Neo Mini 1000 SW has a beautiful 95° wide beam cast in even arching smooth beam with no hotspots or edge drop-off.
    Spot mode made easy! Just a single press of the Neo’s control button and Neo’s beam angle switches from 95° to 25° 600 lumen spot beam, perfect for macro video. The Mini’s narrow spot beam works to isolate small subjects from their background. Leaving the background of your composition unlit and dark provides excellent contrast to highlight the foreground subject.
    FIX Neo Mini 1000 SW specifications
    • Lumens: 600 Spot/1000 Wide
    • BurnTime (min): 100 Spot/90 Wide
    • Beam Angle: 25° Spot/95° Wide
    • Charge Time: 2.5–4 hrs
    • Swappable Battery: Yes
    • Adjustment: 25% steps
    • Depth Rating: 100m
    • Weight: 160g (air)
    • Mounts Included: YS
    • SOS Signal: Yes
    • Model Number: 30395
    • MSRP: $299 USD
  2. SOLD...
