Smc 1 verses plus 10 macro lenses.
Started by steve c r ·
  1. Hi all and thanks in advance for any input.
    I am looking at buying new macro lenses, I already own Reefnet plus 5 and plus 10 lenses which i use on a Nikon d7100 in a nauticam housing .(crop sensor)
    My question is this , which is most powerful the smc1 or the plus 10? I want a more powerful lens with a good working distance if possible. Its difficult to get to compare these lenses myself without purchasing first due to where i live. Oh nearly forgot will be using with 105 and 60mm nikon lenses.
    Cheers steve.
  2. Well you are going to run into some laws of physics issues. The SMC is stronger than +10, it is about a plus 12 or 12.5. The CMC is stronger, the SMC-2 is stronger still, BUT as you add diopter power working distance and DOF will both get smaller. With the 105 the +10 will give you about 2.2 magnification, while the SMC will give you about 2.5 x. WIth the 60 the +10 will give you 1.5 x and the SMC will give you about 1.7 x.
    Bill
