Panasonic GH5 Dual IS and Leica 12-60mm test
Started by Interceptor121 ·
  • 13Posts
  • 13Replies
  1.
    I shot this snorkelling and skin diving video to give an idea of how good is the dual IS of the leica 12-60mm
    I have used it with a 3d gear the 6" dome port and mini extension 30 and I am extremely happy with it
    The sharpness is outstanding even at f/2.8 and the stabiliser works a treat
    The clip has no post correction other than white balance but I have used a LUT in FCPX see what you all think...
  2. Did you have E-stabilization (video) on too?
  3. No I left it off as it crops the picture
    All footage with dual IS 2
    The sea was not flat especially the dugong part as you can tell
  4. What housing, and ports did you use? And is it the Panasonic Leica DG Vario-Elmarit 12-60mm f/2.8-4 ASPH. POWER O.I.S. you have been using?
    I own this lens, and is currently trying to decide which uw-house to buy.
    Great to se so wonderful videos with this lens!
  5. Nauticam NA-GH5 with 6" acrylic dome mini extension ring 30 and 3d printed zoom gear
    The standard option is to get the 7" acrylic dome but I already had the dome so I am reusing it with an extension. It won't fit the nauticam zoom gear
  6. Do you find the zoom from 35-60 to be useful underwater?
    I like my 12-35 II but there is a big gap between that and my 60mm macro, and wondering if I would find the 12-60 useful for sharks and stuff, or close up portrait?
    (plus I can use it inside my 7" dome)
    Would be a nice "all rounder lens" upgrade for topside too...
  7. What options did you use to export? There is significant banding in the blues that why i am asking. Was it shot in10bit?
  8. @dave the focal lengths over 35 are extremely useful I believe the 12-35 is too short
    @lion2fish I shot in all intra 400 mbps 10bits and I have no banding of any sort in any of the clips however youtube converts what you upload and also renders in variable manner
    Where do you see it most? I noticed the part where the turtle swims up which in my original files is fine...
  9. I have checked the files. The source files do not have it the ones I use at home do not have it either (HEVC)
    For youtube I have used YouTube recommended upload settings
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L5.2
    Format settings : CABAC / 2 Ref Frames
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 4 min 11 s
    Bit rate : 40.0 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 23.976 (24000/1001) FPS
    Minimum frame rate : 23.974 FPS
    Maximum frame rate : 23.981 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.201
    Stream size : 1.17 GiB (99%)
    Writing library : x264 core 155 r2901 7d0ff22
    Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=30 / keyint_min=15 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=2pass / mbtree=1 / bitrate=40000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=300000 / vbv_bufsize=300000 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Encoded date : UTC 2018-11-11 09:48:15
    Tagged date : UTC 2018-11-11 09:48:15
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    And those produce tiny banding in the video for few seconds around 55" elapsed however in youtube almost the whole part of the turtle going up has got banding introduce by their compression
    If I try to upload the prores version that is 12 GB and it will take a long time...youtube tells me the video is not optimised for upload and that it will take forever...!
    I believe the only possible way to completely eliminate the issue is to make it HDR conformant so that it takes 10 bit colour however I have decided to work in Cinelike D as I am not able to grade properly HDR
    This kind of clip probably would have been a good candidate for HDR considering the dynamic range and colour however in practical terms when I watch this in 8 bits HEVC it looks already great
  10. I ve watched it on macbook pro i ll watch it again on tv and let you know
  11. I ve watched it on macbook pro i ll watch it again on tv and let you know
    If you use Safari it will limit to HD so the bitrate will be low. On chrome or firefox it will use the full vp9 codec however I can tell you it has banding in that sequence no matter what as there is a lot of water and the encoding crushes it
    I have uploaded at 40 mbps you can push it to 45 before it goes beyond recommendation but frankly I do not think that is the issue the problem is H264 the file I have created for my personal use on HEVC is 18 mbps and it looks much better
    H264 for 4K is not good period and the one youtube uses VP9 is crap too
  12. @dave the focal lengths over 35 are extremely useful I believe the 12-35 is too short
    Thanks, I was afraid that you'd say that... ;-)
  13. Thanks, I was afraid that you'd say that... ;-)
    Obviously this lens is ideal if you want to have a rectilinear lens otherwise with a wet lens like the WWL-1 you can zoom and get a similar effect
    One thing really impressive is the quality at f/2.8 and the type of work you can do at 60mm
