Sea&Sea YS90DX
Started by Ar0n89 ·
Sea&Sea YS90DX
  1. Hello folks,
    Does anyone have experience with the Sea&Sea YS90DX?
    Do they properly work with optic fiber?
    Francesco
  2. Hi Francesco,
    I used this strobe for quite some time with good results. You can use it with a Sea & Sea optical cable, just stick a mounting block on the slave sensor at the front of the strobe. Set the strobe to slave and you're in business.
    This is what I mean with mounting block: https://reefphoto.com/products/fiber-optic-mounting-block-1-hole
    Best regards,
    --Rob
