FS: Olympus Tough TG-5 + Seafrogs Housing + Wide Angle Wet Correctional Dome
Started by patrickkwk ·
  1. I am selling a pretty new TG-5 setup (4 months old). This setup is very good for beginners who want to start up underwater photography. The TG-5 Microscope mode is very good for macro photography that you do not need to use a macro wet lens to shoot critters.
    The TG-5 does not come with warranty because it was bought from Amazon.
    Looking to sell the entire set for SGD 1000 nett.
    Can split the items as follows:
    1. Camera + Housing @ SGD850 nett
    2. Wide angle lens @ SGD 200 nett
    Looking to deal in Singapore.
    Olympus Tough TG-5 includes:
    1. Camera
    2. USB Charging Cable
    3. Charging plug (2-pin US)
    4. Battery
    5. Warranty card (Amazon US)
    6. Manual
    Seafrog Housing for TG-5 includes:
    1. Housing
    2. Manual
    3. Wrist strap
    4. Screen shade
    5. Spare O-ring, cleaning cloth, and lubricant
    6. Neck strap
    7. Anti-fog inserts
    The unique features on the Seafrog Housing that outperforms the Olympus original housing are:
    1. Depth rated to 60 meters
    2. Double threaded front 52mm & 67mm
    3. Dual O-ring seals with Leak Detector
    4. Dual fiber optic ports on the side so that the cables do not cross path with the lens
    Disclaimer: There is a small spot on the housing front glass, but I did a test shot with the camera in the housing and the spot cannot be seen in the picture.
    Test shot:
    Wide Angle Wet Correctional Dome:
    Sample underwater shots taken with this setup and strobes (For macro shots, no lens was used):
    Wide angle
    Macro
