FS Aquatica D800 Housing, D800E, lenses, Ports, Inons
Started by uwphoto48 ·
  1. Aquatica D800 housing excellently maintained (serviced by Backscatter annually). Housing is setup for Nikonos Bulkheads or Fiber optic Bulkheads with appropriate circuit boards, all included. Nikon (USA) D800E DSLR. Mini Macro Port, Standard Macro port, 8" acrylic Dome Port, 9.25 Aquatica glass dome port. Port Extensions for: Nikon 105mm D Micro port extension, Nikon 105mm AFS micro port extension, Nikon 16-35mm port extension w/ zoom gear, Tokina 10-17mm port extension w/ zoom gear, Tokina 10-17mm w/Kenko 1.4 port extension w/ zoom gear, Nikon 200mm Micro port extension, Nikon 20-35mm port extension. Aquatica TLC Strobe arms. Inon Z240 Strobes(2) w/ Inon fiber optic and Sea & Sea cables. Inon snoot. Retra Ultimate LSD Snoot. Tripod housing tray(uses TLC arms). Beneath The Sea cross bracket for Aquatica Housing. Backscatter vacuum system for housing. Aquatica +10 and +5 wet diopters w/ mounts for mini macro and standard macro ports. Pelican travel case. This equipment was purchased and solely used by myself.
    The only lenses I would be willing to part with are the Nikon 60mm D Micro, Nikon 105mm D Micro.
    $9000.00
    Edited by uwphoto48
  2. Hello,
    How much are you asking for the snoots?
  3. Would you sell the strobes separately?
  4. System if off the listing now. Thanks
  5. Not trying to be rude but I love to buy the 200mm port extension. Is it the 18454 or the newer 48454?
    /Fredrik.
