Nauticam 67 mm Flip adapter on Isotta Port? Or Nauticam Port on Isotta Housing
Started by Susa ·
  1. Hi all,
    is this combination possible:
    Nauticam 67 mm Flip Adapter with CMC 1 on Isotta Port 67 mm?
    Or Saga Flip adapter with CMC-1?
    Or is it possible to use a Nauticam Makro Port on Isotta for Plympus omd1 mII housing with 60 mm Macro or 12-50 mm (would be my favourite) ???
    Which combination would you use? At the end minimum I would like to use CMC-1 for my 60 mm Macro with flip adapter. Closest to Port as possible ...
    Thanks!
    regards
    Susanne
  2. Hi Susanne,
    send Manfred from Unterwasserkamera.at a mail.
    He is doing Adapters....
    I am using a Nauticam macro port on my Hugy....
    The Nauticam macro wet lenses are a bit tricky, the thread is not at the absolute end of the wet lens....
    So you will need some space between wet lens and port front glas!
    Regards,
    Wolfgang
