Does DSLR viewfinder diopter setting change for underwater use?
Started by banjobees ·
  1. Good afternoon-
    I dive with prescription bifocal mask and can see my computer, etc well underwater.
    Just got a Sea & Sea MDX-d7100 housing. If the d7100 camera's viewfinder diopter is set so that image and data are sharp on land, will that same setting be good underwater?
    Is it something I should check underwater in a pool or lake before taking it on a dive?
    ( I am asking because the diopter adjustment can't be changed when the camera is in the housing )
    Thanks for you help!
    David
  2. I wear bifocals above water.
    I have lens made and installed in my dive mask for general underwater vision.
    For in focus shooting, I have trust my Nikon auto focus over my eyesight since I gave up the Nikonos!.
  3. Hi David
    You'd still be looking at the same focal length on your viewfinder underwater as you would above water. So I don't think it shouldn't make any difference. But, sure, check it out if you can in advance of a dive trip.
    As Okuma suggests, all else being equal (sediment in the water, fast moving critters etc) trust the Nikon auto-focus! But you should be able to read the viewfinder information as clearly underwater as topside.
