How-to eliminate scratches where the main o-ring makes...
Started by giftie ·
  1. How-to eliminate scratches where the main o-ring makes...
    ...the seal with the housing back?
    In particular for Aquatica housings.
    I have a couple of scratches running +- perpendicular [which are likely to compromise the seal] to where the main o-ring sits, anyone had the same problem and was able to fix it without going through the process of re-anodizing the whole thing?
    Help bery much appreciated.
