Sea & Sea TTL
Started by Ministryofgiraffes ·
Sea & Sea TTL
  1. Hi guys, Im shooting with a nauticam/Nikon Z7 with nauticam TTL trigger and sea & Sea strobes set to DS-TTL setting but the flash is completely blowing everything out.
    I have macro port on and its daytime shooting at 75ft in clear conditions, but I cant work out why the flash is so strong that its massively overexposing everything.. after the shot the viewfinder is complete whiteout... have I misssd a setting? I basically just switched to manual and dialed down the settings and the strobes are fine, but the TTL is a nonstarter.
  2. Hey!
    Can you set a minus flash compensation on the Z7? You could try, say, -3 and see how that works.
    Or does the Nauticam TTL trigger have settings (maybe dip switches) for specific strobes and have you got those set right (sorry, I don't have a Nauticam system)?
  3. I tested Z7 camera with Nautican #26308 TTL-Converter previous week. TTL lighting worked normally. It is recommended to set -0.5Ev flash exposure compensation in menu, - this is right correction. Also, I advice to use "spot" type metering in that camera, to get maximum TTL accuracy.
    By the way, last boards #26308 (manufactured since January) have updated firmware, Z7/Z6 cameras are automatically detected there, and -0.5Ev level is already preset as default zero setting for Z cameras. Those new boards don't need -0.5Ev correction for Z7.
    Anyway, If your Z7 camera requires more than -0.5 Ev correction for TTL now, it means that something wrong in setup or wrong camera settings.
    Do you have User's Manual for that TTL board #26308?
    I can help to clarify the problem, if you want, in messenger.
    Edited by Pavel Kolpakov
  4. Thanks all. You bunch of legends..
  5. Thanks all. You bunch of legends..
    Pavel is indeed a legend.
    :notworthy:
  6. ....
    Thank you guys. But I am a simple engineer.
