Fisheye Fix Ring Diffuser
Started by ulcs ·
  1. STROBE RING FOR OLYMPUS TG's
    Flash ring Olympus TG-5 & 4 for use in microscope mode
    More information
    The TG Flash Diffuser uses a built-in flash on the Olympus TG camera body to evenly illuminate your subject for completely shadow-free u/w macro photography.
    With this product, the underwater case's (PT-058/PT-056) closest focusing distance to the subject is less than 1cm.
    Used once, slight scuff on black part
    No power supply required. Easy attachment and detachment can be done simply by screwing into the housing.
    Equipped with optical fiber connector (SEA & SEA type), it also supports connection of external flash and EF mode mounted light.
    I bought it in Japan.
    Comes with simple instructions, works great
    $60.00
    Edited by ulcs
