Canon 8-15mm on Sony
Started by jemery ·
  • 13Posts
  • 13Replies
  1. I switched from Canon to Sony one year ago now and generally been happy about the switch. Due to being a hybrid shooter, who needs to provide 4k video to clients. But recently my work has shifted toward more photography than video and I am really missing CFWA and the 'fisheye look' that came from my previous setup (Canon 7D and Tokina 10-17mm). I still have the Tokina 10-17mm in my arsenal and have adapted it with a cheap Fotodiox Pro Smart adapter onto my current Camera a Sony a6500. Unfortunately, I am unable to use the Tokina daily as it is too unreliable with AF (with photography) and even locks the camera completely on some occasions.
    I have since decided to upgrade to full frame and have chosen to stay with Sony A7iii as I still need the excellent video performance from the Sony. But the problem still exists that Sony doesn't have a dedicated Fisheye Zoom. Whilst searching the interwebs with continuous research on the best options I have come across the fantastic Canon 8-15mm Fisheye which can be adapted to the Sony by a Metabones adapter. I have read a few threads and articles on people using this setup but with not much detail of its success. I would like to know if the AF works, (luckily I am in warm tropical waters so ambient light isn't too bad) also if it ever crashes or locks the camera? Anyone with a Sony A7 series camera and the Metabones Canon setup could share some light would be most helpful.
    I have also looked at other options like the Sony 16-35mm and the very expensive Nauticam WACP but have ruled both out because the 16-35mm is still a rectilinear and the WACP is too expensive.
  2. Hi Jemery,
    I'm using the Canon 8-15 mm on a Sony A7rIII via a Metabones V. It works well – continuous lock-on autofocus etc is fine. I haven't had any significant issues (I've been using it routinely since September 2018).
    Here are some example photos: https://www.simonjpierce.com/sony-a7riii-underwater-review/
    Note that I'm just updating this post now, but at least you can see the photos. Let me know if you need a closer look at things, I can always send through a few pics. I've been really happy with it, although the Metabones + port adapter adds a lot of bulk / expense to the system.
    I'd look at the 140 mm done rather than the 100 mm I've got, too, although corners are generally okay when stopped down to f/10 or more.
    Best,
    Simon.
  3. Fantastic Simon, that has given me some hope. I will most likely get this setup.
    I would love to see some more photos in detail if possible
  4. Hi James,
    I have used the Canon 8-15mm and Metabones adapter with Sony A7 II, A7R II, A7 III and A7R III cameras in Nauticam housings with Zen 100 port, Nauticam 140mm port & Nauticam 230mm port, all with the removable port shades or blades. I have also used the lens with Ikelite housing and eight inch dome port and with the Acquapazza housing with Inon port II which is 162mm also with the dome shades removed. The large ports work best for split (over/under) images and the small 100 and 140 work best for CFWA. I reviewed these products for uwpmag.com which is a free PDF download. Further info and images can be found in the free back issues, #93, 102 & 103.
    Some images at the circular fisheye end.
  5. Lovely pics, Phil
  6. Thank you Tim. One of the things which is common to all of the housings and port combinations I used with the 8-15 zoom is the purple/blue fringing around the outside edges of the 8mm circular fisheye shots. Nothing I have tried in Lightroom seems to get ride of it.
    This image is with the 8-15mm on the Canon EOS R with adapter and no difference from the Sony cameras.
  7. Thank you Tim. One of the things which is common to all of the housings and port combinations I used with the 8-15 zoom is the purple/blue fringing around the outside edges of the 8mm circular fisheye shots. Nothing I have tried in Lightroom seems to get ride of it.
    Yeah, I remember there was some discussion of this a while back with Adam and Alex. I wondered whether it was Lightroom-outable. But I guess not.
    From the topside pics I've shot with the 8-15, that fringing "only" seems to occur when bright light is on the lens. I'm going to attach a couple of shots from inside a Myanmar temple. You'll see that one shot, with a very dark background, has no fringing; whilst the other has fringing around the lower edges but not the top. Interesting....
    I'm off to Bonaire soon and plan to try the 8-15 out with the Kenko TC1.4. I've got various (Subal) EXRs and zoom rings ready to go.
  8. Hi James,
    Apologies for the delay! I can't work out how to upload pics here, so I'm sending some raw files over to you via email so you can check them out for yourself. All the recent wide angle shots on my Instagram account have been taken using the Sony A7rIII / Metabones V + Canon 8-15 mm combination.
    https://www.instagram.com/simonjpierce/
    I've been really happy with the system overall, which is fortunate, as it cost ALL the monies...
    Very best,
    Simon
  9. Simon - maybe not cheap, but worth every cent!!
    Wolfgang
  10. Thanks everyone for your input, it has been very informative and helpful.
    Big thanks to Simon and Phil for your example photos.
    I will update as soon as I upgrade in a couple of months
  11. Resurrecting an old thread here, but I wanted to record my recent experience with the Metabones version V adapter with the Canon EF 8-15 on Sony for those who may have had problems with the metabones adapter, or who think the Sigma is the only option.
    For video, I normally have my A1 and A7SIII focus set up as follows:
    Default focus mode for video mode set to MF (Manual Focus)
    Rear focus button customized as a toggle between MF and AF-C (Continuous autofocus)
    Shutter button customized to AF Start only
    In terms of workflow, I normally record with the camera in MF, and use the shutter button to execute a AF-S (Single autofocus). This is because in AF-C, the camera will often try to lock into things in closer proximity than the subject. Small fish, bits of stuff in the water can all cause the camera to hunt. So I find it much better to AF-S on the subject and lock focus while rolling footage. The shutter trigger will also execute AF-S while rolling.
    I would like to start using the Canon EF 8-15 for some things, but quickly found that, while the lens would autofocus in still capture modes, it would not do so for video. It was due to the Metabones adapter. However, I found that the most recent firmware version (as of this posting), version 0.70 now allows both AF-C in video mode, as well as AF-S while rolling footage.
    Firmware update for the Mark V Metabones  Canon EF to Sony E mount adapter is here:
    https://www.metabones.com/article/of/EF-E_Firmware_Mac
    The autofocus works and is smoother in advanced modes however considering this is a fisheye lens pretty much everything is in focus very soon so continous autofocus is only required if you keep recording for very long sequences and the subject distance changes a lot
    Generally I dont use autofocus with fisheye nor any water contact optics and I use single autofocus also for photos
    With a rectilinear lens different story depending on the focal length
