I-Das TR-03 & Pistol Hand Grip Connection Issue
Started by Samir.singh ·
  1. Hello fellow divers-photographers, I recently purchased an I-Das TR-03 tray along with a pistol handle ball mount grip, also by I-Das. I am having some problems with the screw in connection and was hoping for some advise.
    The pistol handle screw at the bottom (see attachment) tightens to a maximum point on the bottom of the tray yet still, the handle grip has some movement on the top, is this normal?
    Secondly, I cannot tighten the screw at the bottom any further as both the screw and the handle grip start to move together. Is this normal too?
    Anyone facing a similar issue and what does one do to resolve it?
    I was thinking a thin washer, where the handle connects on the top part of the tray might help but not sure if this will solve the problem.
    Any advise appreciated.
    Thank you :)
    kindly excuse the Cantonese/Mandrin print on the sheets :P
  2. Added a second washer and solved the issue. Figured the handle screw was turning the entire unit since it's height was just a mm above ideal.
