Sigma 12-24 in Sea&Sea??
Started by DavidSD619 ·
  • 14Posts
  • 14Replies
  1. Sigma 12-24 in Sea&Sea??
    I just purchased a Sigma 12-24 DG HSM for my Canon D60 (I know it's 'old', but so am I).
    I am trying to figure out if I can use my Sea&Sea DX60 housing with it. Camera store says when they contacted Sea&Sea they said NO.
    Anyone have this lens in Sea&Sea DSLR housing. If so, what port/ring/zoom gear?
  2. I don't have the lens myself, but if you do get it setup, please do post as I have the same camera / housing combination.
    Tom
  3. I used to shoot with Sigma 12-24 and D60. You can use the lens easily. You need the 40mm port extender for the dome. On the other hand you can't get zoom gear from S&S but I managed to make it from one dedicated for Canon 17-40mm. I mean a friend of mine, blacksmith did it.
    Anyway I gave up 12-24 for the 14mm lens which is much much better.
  4. I bought a sea and sea NX fisheye dome on ebay and lens fits inside. Since lens length is fixed (zooms internal to outer lens case) it seems to work. No extender or +3 +4 manify filter needed.
    Tried it in swimming pool this afternoon and pictures turned out great! Now all I need to figure out is the correct zoom gear and see how it works in open water :)
  5. A quick upload shot taken in Belize last week.
    Sigma 12-24 w/Canon D60 in Sea&Sea with just fisheye dome.
  6. Nice shot!! Great exposure, but I was wondering- is that a vertical shot or is it cropped?
  7. It's verticle. No cropping.
    Only problem is I couldn't find zoom ring to fit housing before I left. Will keep searching.
  8. David I made myself a Sigma 12-24 EX zoom gear for Aquatica Housing with a sewing machine strap like a picture below, It´s an alternative.
    regards
    Mauricio
  9. Mauricio,
    That is brilliant - congratulations from one engineer who salutes your ingenuity!
    Can you help us out by posting the exact model or part number for what we would call the sewing maching _belt_ that you used?
    Thank you!
  10. Thanks James
    It’s from Germany and there are many numbers and letters in the belt. I don’t know how the part number is exactly.
    HTD 276-3M and 331AG
    regards
    Mauricio
  11. You got a sewing machine belt from Germany to Brazil? Please provide any more details you have - how did you find that particular belt?
  12. No, I went to a store in Brazil with my lens and gear and I tested many belts until to fit !!!! I think that the brand is 3M.
  13. Look at this link http://www.correias.com.br/3m.htm . 3M is not a brand it´s a belt step. The model of this belt is HTD 276-3M . The belt circumference is 276mm
  14. Thanks for the info!
    Now all I have to do is find a shop that sells sewing machine belts.
    The distance between the gear and zoom ring of the 12-24 is so 'thin' that the belt may be the only thing that works.
