Strobe on Kraken Hydra 3500S+ WSRU
Started by ncr ·
  1. Hello, I am looking into getting into underwater photography. Been doing a lot of research in setting up a rig, decided to go with the RX 100 V for a starter camera. I didn't want to take my D500 underwater without the higher priced housing, and the RX seems more versatile.
    My main question is about the strobe feature on the Kraken Hydra 3500S+. I was hoping to get some comparison to a strobe like the YS-D2J. I'd imagine the Kraken wouldn't have nearly the features as the YS-D2J but wasn't sure of the differences since I can't find much out about the strobe feature for the kraken. I'd like to get some high quality photos so I would like some good strobes, but figured if I could get a dual purpose light for video or strobe that would be a cheaper starting option. But I'd like to know how well that flash works before I go for that setup.
    Any help would be greatly appreciated!
  2. The strobe feature on that light is useful for two purposes:
    1. Not scaring away mobile subject with a constant bright beam
    2. Syncing cellphones without a mechanical shutter
    As far as power goes, it does not, in any way, shape or form, compare to a xenon flash. See this thread for power comparison between a 14K lumen light and YS-D2: http://wetpixel.com/forums/index.php?showtopic=63437
    Add two more stops of light difference between 3500lm and 14000lm light, and you arrive at 7-8 stops of difference - between 500 and 1000 times the power level.
  3. Thought that was probably the case, probably stick with dual strobes and go with a video light that can double as a focus light. That was a useful link, thanks!
  4. If you want a combination strobe and video light, there is the i-Torch Symbiosis series. The earlier models were basically a strobe and a light clipped together, but SS-3 is a fully integrated unit.
