Why not AWB for UW video?
Started by MitHere ·
  1. So, I'm getting a Sony RX100 VA and will be doing -mostly- bluewater/good vis video in tropical locations in the top 5-20m of depth.
    1) I was recently alerted to the fact that white balance is an issue with the RX100 V/VI cameras - why can I not simply use auto white balance in video mode and adjust colour afterwards in Premiere using fast color corrector and such?
    2) Also, I noticed something about there being a white balance meter in the centre of certain photo modes (which I presume would be easy to just use a white card for WB) however this feature is not available in video mode. This then goes on to note this does not matter as video can be started in any mode.. is the significance of this that you can do the white balance in any mode and then start video, thus tricking the camera into using the white balance you have set?
    3) Shit this sounds like a lot of work freediving :-D
    Cheers guyz
    Adan
  2. I don't have RX100 VA (I use a Panasonic GH5 which allows for MWB in video). The reason you want to do a manual white balance is that you aren't shooting in RAW with video, and therefore don't have the same flexibility in post.
  3. 1. Sony has issues with custom white balance in water it tends to error a lot.
    2. You can use auto with a filter
    3. As auto white balance as a range up to 7000K you would loose a lot you can't recover in post
    4. For freediving if you shoot during ascent and descent colors will be off anyway. Custom white balance does not hold with depth changes
  4. What about using lights?
  5. What about using lights?
    With lights you can work with auto some people set wb to the temperature of the lights not always worth it especially for wide angle
    For freediving depends how deep you are you can set it to a preset appropriate on the day. At shallow depth lights have little to no effect
  6. <snip>
    Cheers guyz
    Adan
    Free diving alone, without the added complexity of trying to take photos, sounds like a lot of work to me.
  7. This is a video I took snorkelling and skin diving to around 40 feet
    I want to have a streamlined negative rig with no lights and a small dome however here I had a 6” dome it was hard work
    Edited by Interceptor121
