I recently got the sony a6400 with a sigma 16mm 1.4 contemporary lens and i am looking around for housing options.
concerning the nauticam housing i coulnd't find any information regarding recommended ports for this lens, has anybody used this combination before
and could recommend any options ?
the ikelite and fantasea housings do have recommended ports for this lens and so does the cheaper seafrog option.
thanks in advance for your input !
You can often work this out - see if fantasea recommends the same port extension for your lens and any other lens. Looking at Fantasea's charts they recommend the same port/extension for the 16mm f1.4 and Sony 10-18, so see the recommended ports for the 10-18mm on Nauticam's port charts.
thanks for your advice !
that's a great starting point i'm assuming i will look into it some more !
Hi,
please write your pro and cons down here.
Specially with "exotic" lenses,
its hard to find the right port!
And not everybody had to do the same mistakes year after year...
Wolfgang
