Bonica Neon XP strobe
Started by Jaardo ·
  1. Almost new (used once) powerful underwater strobe light with (or without...) 4 pre-flash settings. It works with any underwater digital or film camera that has a built-in flash. Along with manual control a microprocessor controlled exposure sensor automatically regulates the intensity of the flash to provide proper exposure at apertures from f/2.0 to f/4.0. Say farewell to trial-and-error lighting adjustment, it puts point-and-shoot simplicity back into the hands of digital photographers.
    The Strobe also has a fully adjustable arm and flash head that swivels 360°. This will allow you to aim the flash in any direction. The Neon Strobe Light has dual sensors which allows it to fire simultaneously when the camera flashes, without the need of a sync cord. It also enable you to put it on any side of your camera.
    Double silicone seal rings give better protection from water leakage.
    Coverage Angle : 60°
    Depth Rating: 165' (50m)
    Flash Modes: Auto or manual
    Exposure Control: Manual or auto at f/2.0 to f/4.0
    Slave: Yes, 4 Pre-flash setting, No pre-flash
    Color Temperature: 5700° K
    Recycle Time: 0.3 to 5 Seconds
    Flashes (Full Power): Approx. 120
    Power Source: 4x AA Batteries
    Dimensions: 3.5 x 4" (88.9 x 101.6mm)
    Weight (Land): 2.2lb (1.0kg)
    Reduced at $95 obo, buyer pays shipping
