Problem with YS-D2 TTL - help!
Started by Divinggobbler ·
  1. I'm in the process of switching from my mirror-less Panasonic GX85 setup with Inon S-2000 strobes to a D810 in a Sea and Sea housing with optical converter and 2 YS-D2 strobes.  So, lots of learning to be had.
    My problem strobe is not working when set to TTL and optical converter set to TTL. The strobe is flashing but is out of sync with the camera so the strobe light is not captured by the camera.  However, the problem strobe works fine when set to manual and the optical converter set to manual.  I have tested the problem strobe with both fiber optic cables and the cable does not seem to be the issue.  It seems that something is wrong with the TTL settings internally to the strobe.
    The other strobe that I have works great and is in sync with the camera in both TTL and manual modes.  I have set the custom mode to A for both strobes.
    Any ideas?
  2. What type of fibre optic cable are you using?  The issue may also be alignment of one of the LEDs of your optical converter with the window in the housing.  You could test that by swapping the camera end of the cable only and see if the problem switches to the other strobe or if the problem strobe starts working.   If you have a Nikon flash try using that to trigger the strobe without the cable - maybe point the nikon flash straight up and hold the sensor facing the strobe to see if it will trigger with a lot more light.
    The S&S strobes are known to have a lot less sensitive optical sensor compared to INON and this is more likely to show up with TTL compared to manual.
