Reliable strobe repair workshop in Europe?
Started by Architeuthis ·
  • 10Posts
  • 10Replies
  1. I have two broken Sea&Sea YS-D2 at home (the strobes refuse two power on after switching them on). I do not want to send them to the Sea&Sea representative in Netherlands, since I sent already one YS-D2 with same symptoms there (they pretend it is irreparable because of water inbrake, but there was never any droplet of water in the strobe). The defective strobe was also not sent back and just disappeared...
    => Is there a reliable workshop existing in Europe, where one could send the defective strobes in for repair (in September my wife and me are going to the next diving vacation in Egypt)?
    Thanks, Wolfgang
  2. I used to get fed up with continual sending YS90s away for repairs, similar symptoms, just not switching on.
    In the end I gave up on paying for repairs and pulled one apart. Inside the on/off switch rotated a cam against a mechanical micro switch. A spray of switch cleaner cured it for a while, but the problems resumed.
    With a bit of careful soldering I replaced the micro switch and everything was good again. I found a similar part with a higher specification.
    I suspect the surfaces inside the switch were oxidising through heating up during high current draw.
    The strobes then performed reliably until I replaced them with Z240s, which have been flawless for 15 years.
    If the on/off switch of a YS-D2 is similar, you could test for the same problem by shorting the switch.
    Take care opening up strobes - there are high voltages that can still be present even when switched off.
  3. Kevin at Aquaphot was recommended to me:
    http://www.aquaphot.co.uk/
    He was very helpful when I called him about my old YS-25A a couple of years back (sadly there aren't any spares for it any more).
  4. What Stig says above. Kevin repaired my Z240 and all has been fine since. Good turn round time too
    Edited by JimG — Spelling
  5. You can try this:
    http://www.teloriparo.com
    They repaired my flooded Inon S2000 and changed the Flashtubes on Inon Z240. I contact them trough Facebook.
    Good Luck
  6. The worksheet of Available Strobes is updated to 12 August 2019.  I have added 2 lists of strobes currently on the US market from Bluewater photo, useful as references of what is available.
    I have also added an early list of Strobe Repair workshops, which is incomplete and needs much information.
    Please feel free to update this Worksheet. I hope you find it useful.
    Hey Kraken
    Is the link working?
  8. Yes, it was just now, 8/14/2019  in  Google Sheets sign-in, free, no ads or emails: "Underwater Strobe Finder, July 2 "
  9. An update:
    I sent the defective Sea&Sea YS-D2 to the workskop that was recommended here: http://www.aquaphot.co.uk/
    It was repaired, serviced and sent back within 2 weeks. The problem was the defective On-switch, a partially burned front plexi glass and a defective contact on the back door (I ruined the contacts, when trying to fix the problem by myself). Cost with porto was around 250 Euro - in case the flash failes again, I will discard it, a further repair will not be worth the money.
    I can recommend this workshop, good to know there is someone out there who takes care of defective flashes...
    Wolfgang
