FS: Ikelite FL 8" Dome, Flat Port, UWCam 5" Minidome - together or separate
Started by String ·
  1. Ive upgraded my housing so have some older Ikelite stuff to sell.
    Please note these are all for the FL (Four Lock) system NOT the newer mechanisms.
    All of which have been used for several years or more, all of which work.  Reason for selling is i went for Nauticam.
    All items are located in the UK.
    First item:-
    Ikelite 8" Dome #5510.45 (https://www.ikelite.com/products/modular-8-dome-for-dlm-and-fl-port-systems)
    Bought in roughly 2009, saw use for 3 or 4 years before being retired and replaced with a minidome.  Used semi-occasionally for split shots since then but otherwise gathering dust.
    It comes with the neoprene cover.
    Also included is the Ikelite extension port #5510.22 ( https://www.ikelite.com/products/fl-port-extension-for-lenses-up-to-4-125-inches) for Nikon 12-24 / Canon 10-22 and similar zooms
    The dome itself has the usual cosmetic marks consistent with use.  The exterior has a few small marks on the acrylic as expected but these do not show on the images or videos.  Normal surface wear only.
    Looking for £200gbp or rough equivalent for the dome, extension and cover
    Item 2:- Ikelite Flat Port
    Next up is a Ikelite FL flat port #5502.41 (https://www.ikelite.com/products/fl-flat-port-for-lenses-up-to-4-1-inches) for macro lenses up to about 60mm
    Again shows marks and some dust as per use.  Optically no issues or marks at all on the surface.  Does NOT have a neoprene cover
    Looking for £75gbp or equivalent.
    Item 3: 5" precision minidome for Tokina 10-17
    This is a 5" precision mini-dome designed by UWCamera stuff solely for the Tokina 10-17 lens.  Part number:- Prec-5in-Tok-ike
    It can be seen here:-  http://www.uwcamerastuff.com/precision_5_dome.htm
    This was my go-to dome and used for 95%+ of my photography.  As a result it shows signs of usage.  (The photos also show dust from the cupboard).
    IMG_20190819_135428.jpg[/img]
    IMG_20190819_135702.jpg[/img]
    Please note the above photo:- It DOES have a scratch on the front which IS visible in photos and video, particularly areas of blue water etc.  Its not that bad (i used it for months like that) but to get rid of it you'd need some nova polish/wet and dry and do the standard acrylic port polishing to remove it.  I didn't bother because i could live with it and had no source of materials to polish it where i was based.  Please be aware of this - i've gone out of my way to highlight it as much as possible in this image.  All of these are exterior surface, internal is fine and has no markings.
    It comes with the neoprene port cover, shade and so on.  It has the Ikelite 5510.11 port extension with it to fit the Tokina 10-17.
    Looking in the region of £100gbp for it or equivalent.
    All items are located in the UK, postage can be calculated if needed depending on where the buyer is.
    I will sell separately or as a package.  If you want all 3 i can charge less.
    Also, not listed but if anyone is interested in a well used Ikelite 70D housing to go with these let me know - i have that too and can work something out.
    Edited by String
  2. Update..
    The MINI DOME has now been sold.
    The 8" dome and flat port remain available.
  3. On 8/30/2019 at 4:27 PM, String said:
    Update..
    I am the happy new owner of said mini dome. Gave it a micro mesh / nova polish treatment today and I'm a happy customer !
    Glad of that!  I thought it would - as i said, the only reason i didn't bother myself is because i upgraded the housing.  That and the last time i tried to do it myself on another port i own i made such a mess of it i had to send it to a professional to do properly!
      I still get nervous selling anything with a "defect" no matter how hard you try to highlight it to potential buyers!
    Also a bump, the other items are still available and as an added bonus, they dont need micro-mesh!
  5. Little bump
