GH5 audio setup for Nauticam housing
Started by thani ·
  1. Hi,
    The quality of recoded audio through Nauticam housing is not good. What is a good setup/configuration on the GH5 to help improve the audio recoding?
  2. I don't think audio recording is actually a consideration? Other than breathing and occasional banging i have not found audio to be of interest. What do you want to record?
  3. you are absolutely correct but sometimes the breathing ads a dramatic effect :)  and rarely there is a sound from the reef and it’s creatures.
    I am getting a continuous rattling/knocking sound a long with my recorded breathing. Are you guys getting clear sound?
  4. you are absolutely correct but sometimes the breathing ads a dramatic effect [emoji4]  and rarely there is a sound from the reef and it’s creatures.
    The camera autofocus engine can be captured by the microphone if you have continuous focus switches on
    I rarely change focus this days and my audio is pretty clean
    Sent from my SM-A505FN using Tapatalk
  5. What you could be hearing is the neckstrap attachment on the camera that might be moving around as u move, thus rattling?
    if I were you id just add the breathing in post.
    It makes sense, I will remove the neck straps and let you know the findings :)
