Nauticam N85 140mm Dome Vignette
Started by jwmm2 ·
  1. Hi all
    Is anybody using the Nauticam 140mm dome with a Panasonic 8mm fisheye?  I'm curious to know how much it vignettes?
    Joe
  2. I'm using the Zen 100mm dome and there is no vignetting.  Corners of the frame are not perfect though.  Assume you are referring to the note in the Nauticam port charts.  I would be interested to see a sample of the vignetting also.
  3. I'm using the Zen 100mm dome and there is no vignetting.  Corners of the frame are not perfect though.  Assume you are referring to the note in the Nauticam port charts.  I would be interested to see a sample of the vignetting also.
    Interesting. At what aperture you would say the sharpness drops? I am very happy with the 4.33” port but occasionally I get inner reflections when shooting against the light on very special conditions
  4. I have not gone beyond f8 where I can still see a little un-sharpness in the corners.  Atttached file is full frame with an enlargement of the bottom left corner.  Image is at f8, Panasonic fisheye, Zen 100 dome, OLy EM-1 II and Nauticam housing.
  5. I have not gone beyond f8 where I can still see a little un-sharpness in the corners.  Atttached file is full frame with an enlargement of the bottom left corner.  Image is at f8, Panasonic fisheye, Zen 100 dome, OLy EM-1 II and Nauticam housing.
    I think the issue you are experiencing is residual fringing as the Olympus body can’t use the lens automatic suppression not softness overall
  6. The shot is a Raw shot processed in Capture 1 and it has the CA and other corrections all enabled.  My understanding is the corrections are performed in RAW processing using stored data.
  7. https://alanwatsonforster.org/writing/mft-purple.html
    It is a well known issue using panasonic lenses on Olympus body gives purple fringing due to a different UV filter built in the camera body
    RAW processing will not correct it
    From what I can see your image has a lot of purple fringing I don’t see on my GH5 or GX7 shots even shooting at f/3.5
    I was aware of severe issues with the 7-14mm but had not looked into the 8mm till now
  8. So a Wratten 2A gel in rear filter holder will fix it according to the article!  The fringing really only appears in the outer corners.   Of course finding something that obscure is another issue, looks like it will be about $A80 for a 75mm square filter.  I'll start a seperate thread to avoid completely hijacking this one.
    Edited by ChrisRoss
