What is the purpose of the vertical piece on Ultralight tray?
Started by Harin ·
  1. I have the ultralight tray seen below and is wondering what the vertical extension piece is suppose to do? What is the benefit of having the short extension part being at an offset?
    TR DUP1
  2. In case you need to put your hand there for ergonomics
  3. ULCS sells grips that go in the round hole. Possible to put one on each side. One can be lower than the other - good for even more accessories to go on top and not be too high.
    I see, thanks. My hand tend to be on the upper part of the grip because that's where the trigger on my housing is. I guess there are some housing that would require space near the bottom.
  5. The tray can be used with the add-on piece on the left ir the right, whatever works best for you.
