Nauticam Macro port 87 exc condtion in UK
Started by louisemurray ·
  1. Nauticam 87 macro port inc spare O ring, grease used 2 trips
    Nauticam 87 Macro Port with M67 thread is designed to be used with the Nikon 105 VR lens or the Canon 100mm lens on Nauticam underwater housings. On the front of the Nauticam 87 macro port is a 67mm thread which will allow the addition of 67mm diopters for extreme macro. Dimensions: Diameter: top 67 mm; bottom; 132mm; length: 110mm Depth rating: 100m Construction: Hard anodised aluminum alloy Glass material: optical BK-7 (Dia: 65mm; Thickness: 8mm) Weight: 470g.
    Price: UK Pounds 300 or equivalent plus shipping at cost EU
