Ikelite Fiber-Optic Converter for DS Substrobes and LED Triggers
Started by Tommy Schultz ·
  1. I'm selling my Ikelite Fiber-Optic Converter for DS Substrobes and LED Triggers. I used this to attach a fiber optic sync cable to my Ikelite DS161 Strobe (also for sale)
    An upgrade to their 4401 Fiber Optic Adapter, Ikelite's Fiber-Optic Converter does everything that the previous model did and is also sensitive enough to work with internal electrical-to-optical LED flash triggers. These triggers are found in Sea & Sea and Nauticam housings, among others. The converter adapts the electrical bulkhead of any Ikelite DS strobe into a fiber-optic port. Updated electronics make this converter capable of accurately reading the LED signals for fast and reliable triggering. Like the original Fiber Optic Adapter, it is also compatible with any system where the camera's built-in flash can be detected by a fiber-optic cable. The converter automatically configures itself for compatibility with both pre-flash and non pre-flash camera modes, so there's no setting of small switches or confusion over number of pre-flashes. Simply turn on your strobe and take one picture to configure. This device is a non-TTL, manual exposure unit capable of supporting a single strobe. It works with Ikelite's DS50, DS51, DS125, DS160, and DS161 Substrobes. The converter features a depth rating of 295'. Converts the electrical bulkhead of any Ikelite DS strobe into a fiber-optic port. Offers all the capabilities and functionality of the earlier 4401 Fiber Optic Adapter. Features heightened sensitivity for use specifically with Sea & Sea, Nauticam, and other housings with internal electrical-to-optical LED flash triggers. These devices translate camera's electrical signals into a series of LED flashes, which are much dimmer than traditional built-in camera flash. Updated electronics make this converter capable of accurately reading the LED signals for fast and reliable triggering. Compatible with any system where the camera's built-in flash can be detected by a fiber-optic cable. Automatically configures itself for compatibility with both pre-flash and non pre-flash camera modes, so there's no setting of small switches or confusion over number of pre-flashes. Simply turn on your strobe and take one picture to configure. Non-TTL, manual exposure device capable of supporting a single strobe. The strobe's output may be adjusted using its built-in manual power settings. Works with Ikelite's DS50, DS51, DS125, DS160, and DS161 Substrobes. Compatible with the following fiber-optic cables: Ikelite 4501, INON Optical D L-type, Sea & Sea 50107 L-type, Olympus PTCB-E02, Nauticam to INON 26211, Nauticam to Sea & Sea 26212.
    Sale price: $85 USD, Retail Price: $125 USD
  2. Update - this item has been sold already
